Alfred.NESWADBA
en respuesta a: rpayne
>> Each letter in a string of text appear with different line
>> weights. Same goes for the line work as well
Have you looked to the PDF with 100% zoom?
If not make sure you see it with 100% and verify then the lineweights.
That's what I see, not really issues with different letter lineweights:
>> when zooming in the issue goes away.
Well, that is hte nature of pixels on the screen and how your viewer (PDF-Viewer) does antialiasing.
If you have 2 pixels lineweight and then zoom out so 1.5 pixels should show the lineweight you know that a pixel can be colored or not, but not half pixels. If the PDF-Viewer does a good antialiasing you would not recognize this behavior, but without antialiasing you see sometimes a line with 1 pixel width, sometimes with 2 pixels width, and that looks then bad.
If you want to create a PDF for the display, then don't use such a big format.
If you want to have the PDF prepared for being printed to that large size you always will have issues on your display (as long as you don't have 108" display with 300dpi :cara_guiñando_un_ojo: )
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
