rpayne
4847 Vistas, 9 Respuestas
PDF's not coming out clear, blotchy looking
Hello All,
I'm trying to create PDF's using AutoCAD PDF (High Quality Print).pc3 driver. Paper size is 36"x108".  When the PDF is done it comes out blotchy looking.  Each letter in a string of text appear with different line weights.  Same goes for the line work as well.  I have attached a PDF file and a screen shot of the print settings I'm using.  I have tried various DPI's with no change in the look of the PDF.
This is a rare occurrence.  Some PDF's only have this issue when zoomed to extents but, when zooming in the issue goes away.  Zoom out and the issue returns.  This is the first PDF where zooming in still has this particular issue.
I have tried this in both Plant 3D 2018 and AutoCAD 2020 with the same results.  I have also tried using the Adobe PDF.pc3 driver, PDF is not created.  When I look at the Plot/Publish Report, the operation completes but the device reports an unknown error and the job is canceled.
If more information is needed please let me know.  Thanks in advance for any and all help.
Best Regards,
Rick
Etiquetas (3)
