- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
My user is currently using Autocad 2010. For this old version, when he wanted to lengthen a line for eg. he just click on the grip and enter the value, it will lengthen. For other lines that follow the same lengthen value, he will click the grip press up arrow and enter then it will follow automatically without entering any value. ( Kindly see the attached video for reference.)
However, when we install a new version of autocad into his computer, this function dont work anymore. How can we set it up with same setting like the Autocad 2010?
I would appreciate if if anyone knows a solution on the matter, or any other useful advice. Thanks!
¡Resuelto! Ir a solución.
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
With all due respect, but the videos are really bad (..to me - But ok, better than nothing)
I guess (because i can not see in detail the problem 2010<>2018 f.e.)
you stumpled about the changed INPUTHISTORYMODE? Set it to 14 and try it again.
Or DYNMODE? DYNPICOORDS?
Sorry that i can not see it well in the video.
Sebastian
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
If I'm right, then you wish in this case
INPUTHISTORYMODE without bit1, try value 14
Disble the dynamic input mode, set dynmode off / try DYNMODE -3
Sebastian
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
Thank you, Betreff for the prompt reply and solution.
Really sorry for the unclear video, I got the video from the autocad user.
Your method works!!
Thank you thank you..
