Moshe-A
en respuesta a: Anonymous
@Anonymous  hi,
here is a solution specially made for you.
attached rdinc.zip file contains lisp rdinc.VLX + block STA-TAG.dwg. save the dwg in a library folder which is on AutoCAD support files search path (this is important) put rdinc.VLX in appload startup suite - do you know how?
Command: RDINC
Starting number <1>:               ; stations starting number
Increment <1>:                         ; increment number by
Segment length <100'>:          ; by default is 100 feet as you requested
Select objects:                          ; pick 1 continued polyline or spline
RDINC is based on MEASURE, block sta-tag is inserted at scale 1x1. if needed enter bedit and scale it to achieve other scale or you can turn it into a annotative block. the circle inside is covered by a wipeout to hide the polyline beneath.
enjoy Emoticono riéndose a carcajadas
moshe
