cadffm
en respuesta a: ko_bach276
All these options are also part of older DWG to PDF.pc3 /older ACADversion.
Just there wasn't the direct link from plot dialog.
Start an older version and check the options of DWG to PDF.pc3.
But now i am confused, perhaps i didn't understand your problem right (or you should explain what do you mean which option could make the issue)
Please test it with complete new and very small files, just with some objects inside. Still a problem?
Are you disable the background publishing?
Yes, all shojld work like in other versions, but we have to find the problem first.
Sebastian
