ko_bach276
1456 Vistas, 15 Respuestas
Publish Problems - AutoCAD 2018
Running into a few problems with Publish in AutoCAD 2018. We've recently switched from 2012 to 2018...
Here's how we use Publish:
Open Publish
Load what we need to print
Import a specific Page Setup file with all our various settings that we need.
And here's our problems:
1. Printing using the AutoCAD PDF Driver, DWG To PDF.pc3.
-If it's a single print it will PDF just fine, if it's more than one it'll Error out with ERROR: Device not found.
2. When printing directly to a printer using that printers universal driver it will print in weird stuttering bursts. For example if I printed 20 pages the printer will print 1-4, and then 1-12, and then 1-20. This problem goes away when I run it through a .PC3 instead.
Etiquetas (3)
