tboehler
en respuesta a: Anonymous
Did the text I sent work for you?  If you inserted it as a block - you'll need to explode it.
Then edit the outlined text to your desired wording (use command "DDEDIT" or double click on the text). Type new text and close editor.
"Regen" will update the solid text to match.  (this is the field that is linked to the outlined text).
Or are you asking how I created the text and field?
I use this all the time on photos.  you can make it work with attributes on a monitoring well block and so on.
