tboehler
en respuesta a: Anonymous
A simple work around in regular AutoCAD is to use Swiss 721 BkOul BT font and Swiis 721 Bk BT fonts at the same insertion and same size.   Attached is a PDF and the text.
Both fonts are simple text and the "solid font" is a FEILD (Object - text - contents).  Make sure outlined font is moved up in drawing order.  Change layers colors to your desired look.
When I edit the outlined font - the soild font updates on a regen.  only need to type contents once.
Cheers.
