Alfred.NESWADBA
en respuesta a: mguerrisi493
first at all, good to know you can continue your work and you have found a way to work with that drawing.
>> I didn't have to scale the image in the autocad material
>> editor...but I noticed the quality of the custom materials
>> has dropped
Then only idea I have is that Autodesk installs two types of material libraries, a small and a medium library. Maybe the images are exported from the small library and so used instead of the higher quality ones.
That would also explain why you now can render, but I'm totally unsure about that assumption.
At least it could also be an explanation why I had no issues to render your project.
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
