- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
>> I have to reduce also the default texture with the
>> associated bumps or my custom texture only?
It is just to isolate the issue, so try half of them and see if that helps, if not handle the others too.
You might also modify these materials to temporary not use the images, or assign to the objects materials that do not have any texture mapping. We need to come to the source of the item that eats up your memory, these are just steps to get that item.
>> can I let the same name and change the scale only
I don't know your environment, if you change existing images and you have already other projects that use them, it's not the best solution to change the existing images, otherwise you have issues when rendering your other projects. That's why I always create my own image settings and never touch original files.
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
