06-15-2019
05:28 AM
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
06-15-2019
05:28 AM
have you tried my suggestions in the >>>other thread<<<, to reduce the size of the texture images?
You also mentioned that 800x600 is working, so what is the max resolution you get it working before it shows the memory exception?
>> the most common workaround is enabling the 3GB switch
This is very historic, because the 3GB switch is only valid for 32bit Windows, has nothing to do with 64bit.
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
Alfred NESWADBA
