1125 Vistas, 1 Respuesta
Mirroring Text: Block within a Block
I am trying to mirror a junction box block that contains a circle and the letter J that is in another block for the one bedroom apartments. Making it an attribute works when mirroring one block (Junction Box Block), but not when that block is within another block (One BR Block). I attempted to explode the junction box block and block everything as one, which works but now the junction box is not annotative. Is there a way to maintain the ability for a block to be both annotative and contain non-mirroring when nested in another block?
natasha.l
en respuesta a: Anonymous
Hello @Anonymous,
Thanks for posting.
You can create a Parameters & Actions for your block rather then mirroring it.
  1. Open the "Block Editor" for the Junction Box Block
  2. Create a Parameters & Actions to your J Attribute
  3. Use the "Rotate Parameter" selecting the center of the circle, the radius & specify the rotation 90-180 etc.
  4. Use the "Rotate Action" selecting the J & Parameter
  5. Close & save the Block Editor
  6. You should see a grip to Rotate the J
Take a look at this video on how too.
Please "Accept Solution" if a reply or replies have helped resolve the issue or answered your question, to help others in the community.
