GrantsPirate
en respuesta a: Anonymous
DIMJUST = 4 is 'place text over extension line 2'.  So the first and second picks matter when placing the dimension.  Moving clockwise for pick 1 and then 2 you will get the dim between the two extension lines, it is actually putting the dimtext over the ext line 2 which happens to be between the two ext lines.  Dimension in counterclock direction and you still get the dims  over extension line 2 but not between the two ext lines.
So either make sure you pick in the clockwise direction each time or create another dim style to place the text over extension line 1 and pick in a counter clockwise direction.
GrantsPirate
Piping and Mech. Designer
EXPERT ELITE MEMBER
Always save a copy of the drawing before trying anything suggested here.
If something I wrote can be interpreted two ways, and one of the ways makes you sad or angry, I meant the other one.
