Alfred.NESWADBA
en respuesta a: Anonymous
well, first please start command _AUDIT, it shows (and hopfully repair) your drawing database.
Second ... you are having the units issue, looking to command _UNITS your drawing shows "Inch" as setting. Using command _DIST to measure the width of the entrance door it shows a distance of 1500 ... which means the door is 1500 Inches wide ... for cameras it means they are > 1000 Inches from the objects away.
What I did then:
  • moved your 3D-geometry more close to 0,0,0 (to get better render results)
  • selected then the lights and set the multiplier to 1000  (not sure why, but starting with the wrong units always has following issues)
  • and get this result for "Camera7"
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
