06-10-2019
10:27 PM
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
06-10-2019
10:27 PM
@Anonymous hi,
here is my fix, untested cause you did not send all the code. there is a (CHGD) function missing.
about Oblique - 70d? you meant only 15d - yes?!
enjoy
moshe
(defun create_layer (name clr)
(if (null (tblsearch "layer" name))
(command "layer" "new" name "color" clr name "")
); change layer
(DEFUN C:OO ()
(setvar "cmdecho" 0)
(command "undo" "begin")
(SETQ L 0 MID 0 MID 0 AN 0 BRG 0 DIST 0 A 0 B 0 C 0 D 0 MA 0 MB 0 MC 0 MD 0 MID 0 Z 0)
(PROMPT "\nSelect lines to be annotated..")
(setq ss1 (ssget)
n (sslength ss1)
index 0
dim (getvar "DIMSCALE")
ht (* dim 1.8)
(while (> n index)
(setq l (ssname ss1 index)
index (+ index 1)
OFFSET (* 0.6 ht)
L (ENTGET L)
ST (CDR (ASSOC 10 L))
END (CDR (ASSOC 11 L))
AN (ANGLE ST END)
BRG (CHGD (ANGTOS AN 1 4))
AN (* AN (/ 180 PI))
dAND AN
dAND (- dAND 90)
dAND (- 360 dAND)
); setq
(IF (> dAND 360)
(SETQ dAND (- dAND 360))
(IF (>= dAND 180)
(SETQ dAND (+ dAND 180))
(IF (= dAND 540)
(SETQ dAND 0)
(SETQ DIST (RTOS (DISTANCE ST END) 2 3)
A (CAR ST)
B (CDR ST)
B (CAR B)
C (CAR END)
D (CDR END)
D (CAR D)
MA (+ A C)
MB (+ B D)
MC (/ MA 2)
MD (/ MB 2)
ANR (* (* (/ AN 360) 2) PI)
MID (LIST MC MD)
); setq
(IF (> dAND 180)
(SETQ MID1 (POLAR MID (- ANR (* 0.5 PI)) OFFSET))
(IF (> dAND 180)
(SETQ MID2 (POLAR MID (+ ANR (* 0.5 PI)) (+ OFFSET HT)))
(IF (<= dAND 180)
(SETQ MID1 (POLAR MID (+ ANR (* 0.5 PI)) OFFSET))
(IF (<= dAND 180)
(SETQ MID2 (POLAR MID (- ANR (* 0.5 PI)) (+ OFFSET HT)))
(SETQ Z (+ Z 1))
(IF (= Z 1)
(COMMAND "STYLE" "rjc" "rjc" HT "1.00" "" "" "" "")
(COMMAND "TEXT" "C" MID1 dAND BRG)
(create_layer "bearing" 7)
(command "chprop" "si" "last" "layer" "bearing" "")
(COMMAND "TEXT" "C" MID2 dAND DIST)
(setq elist (entget (entlast)))
(entmod (subst (cons '51 (/ pi -12)) (assoc '51 elist) elist))
(create_layer "distance" 1)
(command "chprop" "si" "last" "layer" "distance" "")
); while
(command "undo" "end")
(setvar "cmdecho" 1)
(princ)
); c:oo
