678 Vistas, 1 Respuesta
render prob - "This scene cannot be rendered...must contain at least one 3d wi"
Hi, I've been trying to render my model several times. At first I could, had to adjust lightning and try again. Then, the screen would appear black, now, a sign "the scene must contain at least one 3d wireframe or solid model object to render" titled, no faces to render appears.
HELP!
Etiquetas (4)
Alfred.NESWADBA
en respuesta a: Anonymous
That means your drawing does not have 3D renderable objects in your modelspace (or at least in the render area).
You might upload your drawing so we can describe more detailed what you have and what you need to do with that.
From your screenshot I don't know what you see here, it maybe a background raster, but not sure about that without seeing the dwg-file itself.
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
