921 Vistas, 4 Respuestas
Prefered proccessor and graphics card
I am buying a laptop to use for Autocad 2020 and would like to know which processor is a better selection (Intel Quad core i7 7700HQ or Intel Core i7 8750H) and which is a better graphics card Nvidia Quadro M2200 4GB or GeForce GTX 1070 8GB.  Open to other suggestions
ennujozlagam
en respuesta a: Anonymous
why don't you check the autodesk requirements to run autodesk product so that you have an idea what to buy see this LINK. thanks
en respuesta a: ennujozlagam
Already looked at requirements, but was hoping to narrow it down to get the best processor and graphic card.
Tomislav.Golubovic
AutoCAD is only a single threaded app, so I think you're splitting hairs with the processor. As for the GPU, I've had a 1080 before and it was great, so I'll assume the 1070 is still good.
ian.mag
Hey @Anonymous
These specs meet the bare minimum for running AutoCAD. If it is a matter of preference, consider which other program besides AutoCAD you may wiSH to run on your machine eg. photoshop, after effects etc, then settle on one of the above based on both considerations. Bottom line is, you will be the one using the machine, and the suggestions that the community members may give you may only be based on their preference/liking. So it should and must be able to serve you to the capacity you require.
