06-07-2019
06:07 AM
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
06-07-2019
06:07 AM
@BIMAbhi wrote:As we know that in Revit we can make central file and we can edit by multiple users. So is there any Process available to make a drawing file to central In AutoCAD, and can used by multiple users?
Even in Revit, you aren't able to have multiple users directly edit the central file all at the same time. Each user gets a local file version of the central model to edit, and then each local file is sync'd back to the central model.
So I wouldn't ever expect Acad to work in a way that you can overcome a basic file limitation "feature". As others have said; use xrefs, that's your best chance at coming close to how Revit works around this issue.
