pendean
en respuesta a: BIMAbhi
NO. And it will never change in AutoCAD.
But you can learn about using XREFs in AutoCAD, which splits up your single cad file into separate individual portions that all come together in a top master file, thus allowing may users to use the many separate DWG files all at the same time.
There are many tutorials on the web, help yourself: I will get you started here https://www.landfx.com/docs/cad-basics/autocad-getting-started/item/2544-xref.html%22
