mbriegel
en respuesta a: Anonymous
The issue is the block itself. If you insert the _TagCircle block which is what the leader uses and then use the block editor, you will find that the text is not annotative and the text height is set to .0938 which is .7504% of the .125" height you wanted (or the 25% that you referred to). I have not tried to change the text to annotative in the block but not sure how the circle would look around the text with the various scales but it would be easy enough to test. Hope this helps.
