1022 Vistas, 10 Respuestas
Auto bond option
Hi. I'm currently struggling with auto bond option in Autocad 2020.
My drawings require moving many single parts, and due to that option, I'm wasting a lot of time. I would like to know if there is a way to turn off my option, so my lines would be seperate all the time.
Sorry for grammar misstakes, English is not my native.
Best regards.
imadHabash
en respuesta a: Anonymous
Hi and Welcome to AutoCAD Forum,
what do you mean by Auto Bond option ? :cara_con_una_leve_sonrisa:  did your issue relate to PICKSTYLE (System Variable)  >> Click << . ?  or you have  group objects that you need to UNGROUP (Command) ?  or HPSEPARATE (System Variable)  >> Click << or it's a constraints issue >> Click <<
tell us more please or show us a screenshot for your issue ? :cara_con_una_leve_sonrisa:
Imad Habash
en respuesta a: imadHabash
Screenshot_1.png When im drawing "lines" they automaticly connect. So when i try to move one of them, they move together.
imadHabash
try to use LINE command NOT Polyline .
Imad Habash
Command "line" is the only one im using currently. Thats why I'm surpsised by how it works.
Alfred.NESWADBA
In case you are already using LINE and not PLINE it might be the setting of system variable CONSTRAINTINFER (>>>details<<<), make sure it's set to 0.
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
imadHabash
from above menu bar ( Draw tab ) if you start line command from there , any changes ?
Imad Habash
Here is a short video.
imadHabash
i think it's  constrain issue please type  DELCONSTRAINT and select your lines , any changes ?  check my post #2 .
Imad Habash
Alfred.NESWADBA
have you seen my suggestion about CONSTRAINTINFER?
- alfred -
Alfred NESWADBA
en respuesta a: Alfred.NESWADBA
Thank you so much. That was the command I needed.
You're both amazing. Thank you for everything :cara_con_una_leve_sonrisa:
