en respuesta a: jwhite
@jwhite wrote:
You may be able to use a scale action tied to a linear parameter. Scale the lines you want to disappear by 1/1000 or some similar factor from a visible object. The small scale objects will overlay the visible object and "disappear". Using a lookup table you can toggle between the two scales. I've used the method numerous times.
Thank you. I will look into this. Your method also gave me an idea about moving the dot that's left behind to be under something else in the drawing where it'll be masked. I'm quite sure this could be achieved with the lookup table also. I'll dig into this.
