789 Vistas, 8 Respuestas
AutoCAD 2020 File Format
I AM USING AUTOCAD 2020 FULL VERSION (LICENCE). I GOT INVITED FOR THE TRAINING PROGRAM RELATED BILL OF MATERIAL EFFICIENTLY WITH AUTOCAD. BUT NOW I CANT FIND ANY SUCH TOOL BAR IN MY AUTOCAD. PLEASE SUGGEST ME WEATHER I NEED TO REPLACE MY AUTOCAD VERSION OR IT CAN BE DONE WITH SOME UPDATE BECAUSE IT CAN BE A HELPFUL TOOL FOR MY WORK. I WORK ON PLANT OVERALL DEVELOPMENT INCLUDES PIPING, ELECTRICAL, SUPPORT LAYOUTS AND ISOMETRICS. PLEASE SUGGEST ME AS EARLY AS POSSIBLE SO THAT IT CAN BE IMPLEMENT IN MY WORK
cadffm
en respuesta a: Anonymous
STOP SCREAMING, thank  you.
Your Version (2020) is fine, but i guess you are using the wrong program.
We can not know what you need or want-
MEP ?
REVIT?
Bill of Material sounds like MECHANICAL
https://www.autodesk.com/products
Sebastian
imadHabash
Hi and Welcome to AutoCAD Forum,
make sure that your MENUBAR system variable = 1  then from upper menu bar  Tools ( tab ) >> Toolbars ( AutoCAD ) select what you need .
Command: MENUBAR
Enter new value for MENUBAR <0>: 1
Imad Habash
en respuesta a: cadffm
SIR, WE ARE USING AUTOCAD 2020. IS IT POSSIBLE TO USED THE NEWEST UPDATE
OF BILL OF MATERIAL EFFICIENT TOOL IN AUTOCAD 2020 OR I NEED TO REPLACE IT
TO (AUTOCAD MECHANICAL) TO USE (BOM TOOLBAR)
en respuesta a: imadHabash
SIR I AM ASKING FOR TOOL BAR TO EXTRACT BILL OF MATERIAL (BOM)
ian.mag
Quite a hillarious thread @cadffm  & @RobDraw Emoticono muy feliz
The bill of materials may not be present in Vanilla AutoCAD probably AutoCAD Mechanical/Electrical or AutoCAD Plant 3D. Confirm from the training program you attended whether they were using plain (vanilla) AutoCAD or the above mentioned.
rkmcswain
@Anonymous - take a look at this.
pendean
Your course is not for plain AutoCAD2020, find out what exact variant of AutoCAD2020 they are teaching you on, I suspect it is this https://knowledge.autodesk.com/search-result/caas/screencast/Main/Details/c7b9fe7d-6e16-40d5-b3e6-55...
You probably need one of the verticals https://www.autodesk.com/products/autocad/included-toolsets
RobDraw
Someone must have gotten offended by the image I posted.
Rob
