- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
Program crashes when saving or switching layouts
I've been working in a drawing that will no longer let me save the document without it crashing. Not only can I not save, I cannot switch among my layout tabs without the program crashing either. I have tried the "audit" and "purge" commands with no avail. I have also checked to see the graphic driver is up to date and one that is recommended by the program. I've tried setting "proxygraphics" to <0> and this does not help either. I am wondering if I need to try reinstalling AutoCAD all together or if there are any other fixes/commands I can attempt?
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
I've tried a repair and reinstall and that didn't seem to work either.
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
Not surprised. If AutoCAD is to the point of needing repair/reinstall - it usually won't even run. It's much more likely that you need to reset your user settings (or what some call a hard profile reset). This involves renaming a registry key, and two folders. See this. (the article says to delete the registry key, but I just add a ".old" to the end of the name of it.) This will reset AutoCAD back to the defaults for that user, just like it's never been started up.
I have done this probably 30 times in the last couple of years (for multiple users, not just me) and it works 99% of the time.
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
Is it possible to have the registry file titled something different in my registry tree? I don't have the title "ACAD-E001:409" instead its "ACAD-F022:409". Is this the same thing?
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
Fix this one problem file: here is a long list of many things to try, no one is the miracle cure https://knowledge.autodesk.com/support/autocad/troubleshooting/caas/sfdcarticles/sfdcarticles/AutoCA...
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
Most of these I am unable to do because it won't even let me save, copy, or switch views in the corrupted drawing...
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
Recreate the layouts from scratch and see if that becomes more stable.
Then abandon the original problem file.
