jwhite
en respuesta a: Anonymous
You may be able to use a scale action tied to a linear parameter. Scale the lines you want to disappear by 1/1000 or some similar factor from a visible object. The small scale objects will overlay the visible object and "disappear". Using a lookup table you can toggle between the two scales. I've used the method numerous times.
