en respuesta a: Moshe-A
First of all - Thanks for your work.
Second - doesn't really solve my problem. The range of the AttributeNames (Tags) are very wide something between one and 50.000 - so anything that needs the old name to replace the current one is pretty useless. I could make an excel sheet with 50.000 variations of every Attribute name just with a diffrent number behind it but we're talking about around 150 diffrent blocks and i think with such big data it will just crash. (7.5Mil different attributenames).
Don't really get the coordinate part. Another try to explain it with my broken English-
This opens up with the BATTMAN function and the Tags "NO" and "DATE" are always in this exect order.
Goal is to target the order direct with the script - say -
(setq data^ '( ("Block1" ("Tag_Order_Position1" "newTag1")
	       ); list
               ("Block2" ("Tag_Order_Position2" "newTag1")
 ); setq
Maybe its just not possible to make it this way :x
I also don't have acces to AutoCAD right now to test anything tho..
Still thank you very much for your effort I appreciate!
( A script that changes every attribute name globaly to "XY" would also work tho - atleast i can name them without open every BATTMAN on the block to write them down)
Best regards
