- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
were your CAD files developed for the purpose of using them in therm? if so, i would contact who ever gave you the files and see if they can clean them.
If you are repurposing the files there might be some things you can do but im not familiar enough with therm to know what it needs.
What kind of cleaning are you having to do? if its simple removal of annotation you can use things like quick select (QSELECT) to select elements across the drawing. you can select all the text or leader etc and delete them all at one. Also using somthing like select similar may help. Also if the objects that need cleaning are on certain layers you may be able to manage them by manipulating the layer they are on.
If the clean up involves closing lies etc you can use the JOIN command. Also OVERKILL can be helpful if there is just a bunch of overlaying geometry.
CADnoob
