- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
Hi all!
Recently we have made some modifications where I work and now we need to do extra work and very repetitively for example I need to open 100 different drawings one by one and select a hatch and change it from color red to bylayer which is magenta color 6. also I need to select a line/polyline which is in color green and need to manually change it to color 82.
I found this lisp by Lee Mac that does something similar but not quite what I need.
(defun c:cc (/ usercol ss)
(while (or (not (setq usercol (getint "\nSpecify Colour Code > ")))
(not (<= 0 usercol 256))))
(prompt "Select all object to change to one color.")
(if (setq ss (ssget))
(command "_.ChProp" ss "" "_C" usercol ""))
(princ))?
This ask for user input to determine the desired color and then requests to select the entity and does it perfectly but I need my tool to do it automatically since it is 2 exact processes.
To recap I need help with a lisp that will
- Select hatch any hatch but if the hatch name is needed I can provide it does not need to get into blocks just the one hatch.
- Select green lines/polylines and change color to 82.
- After this process is done I run my plot script.
I will very much appreciate all help provided or any guidance on how I can modify the lisp above to do as I need.
Thanks in advance,
Victor P.
¡Resuelto! Ir a solución.
