- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
Is it a modified template? probably?
The drawing in question comes from a "blank" drawing we keep on file which has our borders, logo, etc. already in place as well as certain XREFS. I did not originate this drawing, however other drawings have the same issue. Including our latest "blank" drawing.
That drawing does list 1:100 as a scale option. However, it experiences the same behavior. In the drawing below I have drawn a 1 inch line in model space (Shown in black). I have traced that line in paper space and moved it up (shown in red). I have used the dimension tool on both, showing that they are both 1 inch in length which is consistent with the 1:1 scale. I have chosen inches so that feet are never involved. 1" = 1" = 1". Finally, I brought in a bar scale (shown in green) referencing the viewport. I have given it Scale bar division of 12 inches to compensate for the 1:12 Scale Ratio. As you can see the 1st division (marked 12) is 1 inch from the zero mark.
If I change the scale ratio to be 1:1. The following happens
