05-15-2019
09:22 AM
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
05-15-2019
09:22 AM
@Anonymous wrote:
The EXPLODE is a good option. Is there away to reverse this after? To make cricles again as Associative Array?
If EXPLODE is a good option, then you don't need them to be an associative Array in the first place. You can make the Array without Associativity initially, and not need to EXPLODE it afterwards.
But the pieces can't be re-associated. Some of them won't be Circles any more, anyway, and those that are Arcs won't be the same as each other, so the "nature" of an associative Array can't be brought into the picture. You can use BLOCK or GROUP to tie them together, but they won't have the associative-Array kind of relationship in which you can edit things like column spacing, etc.
Kent Cooper, AIA
