ed57gmc
en respuesta a: GroveSci
If the 1:100 scale isn't listed, you are using a modified template? You can simply add the scale in the SCALELISTEDIT command. Make sure the scale is 1 paperspace unit to 100 model units. If you edit the 1"=100' scale you will see that it applies a factor of 12, 1:1200. This will not work for you if you have feet set as your unit.
Ed
How to post your code.
