05-15-2019
08:39 AM
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
05-15-2019
08:39 AM
You can join the objects to make one collection of polylines. But that isn't really the recommended workflow. You could copy your array and paste it anywhere in your drawing. Then you can explode the array and edit the section that you want to array. Save that as a block (or join all the features into 1 object) and insert it into your main feature. Then array that feature the desired amount. In your case I believe it was 3 polar arrays.
If this helps you then hit the LIKE button or mark as an ACCEPTED SOLUTION!
Thank You!
Jonathan Focht
