ВeekeeCZ
en respuesta a: cadffm
Your file is good.
While working with the original file, when I added the block as it was (which is just an anonymous block "*U8") to the ToolPalettes and then when inserted to another file, I experienced the same issue. (C3D 2016 as ACAD here)
But now, I inserted the definition to the original file (without any attribute filling), that definition I added between tool pallets, then it behaved as expected.
The issue presented in my screencast still persist.
So my suggestion is - make sure that you add the original block (not an anonymous dumplicate) to the ToolPalettes.
In general, I would try to avoid multiple same tag names if possible.
