ed57gmc
en respuesta a: GroveSci
If you run the SCALELISTEDIT command, you will see the actual ratio used to display model space in a viewport. 1" = 100' is not a standard scale that comes with AutoCAD. Apparently, it was added to work with units of inches, not feet. So, I'm assuming its ratio is 1:1200. You need to use a scale with a ratio of 1:100, which there is a standard scale supplied.
Ed
How to post your code.
