05-15-2019
06:51 AM
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
05-15-2019
06:51 AM
Hello @Anonymous,
When creating an array, the objects making up that array become "locked" which prevents them from being edited. You can get around this if you EXPLODE the objects. Or use the XCLIP command. Select a polyline as a boundary (or create a new one in this command) and then select items to trim.
Hope this helps!
If this helps you then hit the LIKE button or mark as an ACCEPTED SOLUTION!
Thank You!
Jonathan Focht
