- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
Same result. Block brought into a clean drawing environment, from the palette storage drawing works fine. Same block brought in from the Tool Palette, the attribute moves.
If I copy the block that works, it continues to work. If I copy the floater, it continues to float. Like 2 different definitions of the same block. But if I purge, only one definition is found.
I am on 2020, but this has been a problem for years so I don't think it has anything to do with release.
I have tried removing the block from the tool palette, and placing it there again from one that I know works, but as soon as I put it on the palette, it is broken.
Chris Benner
Inventor Tube & Pipe, Vault Professional
Cad Tips Tricks & Workarounds | Twitter | LinkedIn
Autodesk University Classes:
Going With The Flow with Inventor Tube and Pipe | Increasing The Volume with Inventor Tube and Pipe | Power of the Autodesk Community | Getting to Know You | Inventor Styles & Standards |Managing Properties with Vault Professional | Vault Configuration | Vault - What is it & Why Do I Need It? | A Little Less Talk - Tube & Pipe Demo | Change Orders & Revisions - Vault, Inventor & AutoCAD | Authoring & Publishing Custom Content
