cbenner
1114 Vistas, 20 Respuestas
Floating Attribute
Hello AutoCAD Geniuses.
I've been using AutoCAD a long time... a long time.  From time to time I've seen this issue, but finally have had enough and want some advice.
I have a block (actually a family of blocks), see the video, 4 bubbles, each containing an attribute called TAG.  I have 4 of them because they CAN have unique values.  Doesn't matter anyway, I've seen this problem even if the attribute tags are unique.  I have this block in a drawing from which I populate my tool palettes, but it also resides as a wblock in a shared location.  In this palette drawing, if I edit an instance of the block, all of the 4 tags work just fine.  If I place an instance of it directly from the file location, all 4 tags work.  If I pull THE SAME BLOCK (already defined in the drawing), from the palette, one of the 4 tags jumps to hide underneath one of the others.  Always the same one.
In the video, the first two blocks you see were copied and pasted (after a Purge) from the palette repository drawing.  You can see they edit just fine.  I add a third one from the palette (SAME BLOCK), and you can see the tag moves.  If I explode, it returns to base.  If I Burst, it stays under the top tag.  Is this really weird, or do I just need another cup of coffee....
Screencast will be displayed here after you click Post.
5f9e1bcb-4d44-40cc-a508-7239d496f833
