350 Vistas, 3 Respuestas
AutoCad LT 2004 missing file \Bin\AcltFEUI\m2.cab
I have been using the 2004 LT AutoCad for years.  I lost the CD awhile back, however I saved all the setup files to disk.  It appears that I am missing the AutoCAD LT 2004\Bin\AcltFEUI\m2.cab file.  Can someone send me this file so I can save it and complete my setup?
Thanks in advance.
pendean
en respuesta a: Anonymous
Your title says LT2014.
The body of your text refers to a much older LT2004.
Which is it? Because you can probably get LT2014 installation files here https://ava.autodesk.com/ but you are a decade too late for the older version.
en respuesta a: pendean
It is a 2004, I accidentally posted 2014
pendean
Thanks: I will ask the forum administrator to correct your title.
Read this in the meantime about Windows10 compatibility while you wait https://knowledge.autodesk.com/support/autocad/learn-explore/caas/sfdcarticles/sfdcarticles/Windows-...
And Windows 8/8.1 compatibility https://knowledge.autodesk.com/search-result/caas/sfdcarticles/sfdcarticles/Windows-8-Support-for-Au...
