MrMuscl3
en respuesta a: Anonymous
Thanks to everyone for answers!
For some reason my cursor won't change to shape that indicates window resizability with command line when it is undocked. With xref/properties/ribbon the cursor changes its shape when it is moved to border of any of these. Is this a bug or system variable related problem?
However I managed to resize my command line to shape I prefer to use. Even when the cursor would not change its form, the window of command line could be resized.
I looked the LOCKUI system variable and it was as default set to 0. According to autodesk knowledge network, the value 8 would be best after these windows are correctly sized as it is "Floating windows locked".
AutoCAD 2022
