en respuesta a: MrMuscl3
If the command line is docked, either top or bottom, then you should be able to pick and drag the 2 horizontal lines on the left of the command lien window above the "X", once floating you should be able select a corner and drag in any direction to resize and reshape.
You also have the Lock User Interface on the tools strip at the bottom of the window that can lock floating and docked windows.
