MrMuscl3
535 Vistas, 3 Respuestas
AutoCAD 2018 command line shape
I have recently installed AutoCAD 2018. I was using AutoCAD LT 2014 before and had ribbon/properties/xref/command line on other other screen. I like to keep these windows docked next to each other and height set as high as the monitor allows. On LT 2014 the command line could be shaped to any sized box I wish to use. I undocked 2018 command line but I am unable to change its size or shape. Is there any way to change its size and shape?
edit: I would also like to change my forum signature but was not able to find place for this procedure Emoticono indiferente
AutoCAD 2022
