jwhite
en respuesta a: AMD-JEC
I modified my acad.pgp file to use classicinsert instead of insert. That's one of the commands I usually run by typing in the shortcut instead of using the ribbon. If you do use the ribbon you can probably customize it to run classicinsert.
