leeminardi
en respuesta a: imadHabash
When you add a dimension line the object vertices you click are projected to the current XY plane and the dimension line is added on the active XY plane.  The dimension that is given is not necessarily the distance between the two vertices as it is the distance between the projected points.
When dimension a 3D model in AutoCAD you should first set the UCS with an appropriate location and orientation.
lee.minardi
