356 Vistas, 4 Respuestas
ucs out of wack in 3d and placing things away from points
im using a program that runs through cad, and everything that i insert is a block, and you can drag it onto the screen and click to place, however when i dimension the object, i have to do it in a 2d view, except when i switch back to 3d, the annotation will be for example 10037mm away and not attached to the object points.
screenshot attached
