05-07-2019
07:41 AM
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
05-07-2019
07:41 AM
There's a lot more to installing programs than where the files are located. For what it's worth I'd recommend switching up your thinking. Clean up the high performance SSD so there's enough room for the important programs like AutoCAD; you want them on the best performing drive. Move everything else, including temp/junk/etc. to the other drive.
It also sounds like you're trying to install an update/SP rather than the actual program. Go to your Autodesk account and ensure you're downloading the correct item, which should be in two parts.
