- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
Hi, I am currently using Autocad 2019. When I draw a 3 points arc, the arc seems not attached to the starting & last point of the arc. This only happen when I am in 2 viewport mode & the arc look normal in 1 view port mode. Pls help. ![]()
¡Resuelto! Ir a solución.
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
Are you sure you are in a Plan View?
Jürgen Palme
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
what happens when you turn off hardware acceleration (command _GRAPHICSCONFIG)?
Also please show us a screenshot
- of dialog/command _GRAPHICSCONFIG (so we see your graphic card driver)
- of dialog/command _ABOUT (so we see your product and version)
- if possible also let us test with your drawing on our systems.
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
if you copy the same area of your drawing to a new and empty drawing , any changes or what ? if NOT .. please attache here your clouded area for testing ?
Imad Habash
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
I copied the elevation to an empty drawing & the arc looks normal. Thank you for your help.
