- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
I am a little puzzled by a change I just noticed. From time to time, I will draw poly lines that consist of a linked series of arcs and lines. To get the feel right, I depend heavily on undo, in the middle of the process. Up until 2015, if I was drawing an arc and I hit undo, the default behaviour was to go back to the extension of the previous arc or line with a tangent arc and I could continue. In 2018, the after I hit undo the new arc behaves with some kind of included angle behavious that is essentially worthless. What is the point of this?
¡Resuelto! Ir a solución.
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
After hitting a point, I undo (to back up and try a different point
In 2015 (what I want)
[cid:image001.png@01D501A4.D1C65CC0]
In 2018
[cid:image002.png@01D501A4.D1C65CC0]
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
Can't get to a scren shot with the command line, but it's:
PL (for polyline)
[*first point]
[*second point]
A [arc option]
[*point]
[*point]
[*point]
u [undo the last point]
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
so ortho is not the answer sorry. a work around perhaps is just make the arcs separately and then pedit them tougher when you got them how you want them
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
No joy with ortho off - same behavior
Change Direction inverts the curve, (but does not make it tangent)
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
So the problem as I see you want to undo an arch but not change the last arc.
You need to finish the arc command and not hit undo in the middle. so pick a point even if its not right then undo and you can select a new point
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
EXCEPT if the ARC size changes when I move the cursor to an odd angle. But this is very hard to replicate on demand (found it by accident after the 10th try).
Is that how you are doing it?
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
No, not exactly. I am trying to get a single polyline that is a series of arcs and sometime line segments, where the arcs are all tangents.
Sometimes, the location of the point setting a previous arc limits my current arc from going where I want it to.
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
I tried lol. im sorry but I also cannot recreate the problem.
I wish you good fortune in the drawings to come
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
I am thinking it is some kind of oddball variable? But I'm not sure I would know it if I see it.
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
>> I'm sticking with 2015 for the time being
I can't reproduce the issue with AutoCAD 2019. So let us first look to your currently installed updates, start command _ABOUT and show us a screenshot from that dialog (it should show 2019.1.2 ... otherwise your AutoCAD is not up-to-date).
That's what I get following your steps:
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
Unfortunately, since I have 8 workstations, if I want to move to the latest and greatest, I have to upgrade all of them.
And if it's not fixed, then I am totally SOL. So as I said, sticking with 2015, til I know why this doesn't work.
But thanks for digging in. The fact that it's not reproducible is encouraging, believe it or not.
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
>> Yeah. I know it's only 2018
No, it's not 2018, the video I have shown works in the same way in 2019 as in 2018.
It's something on your systems (or missing updated for your 2018, mine is O.161.0.0 AutoCAD 2018.1.2 Update)
- alfred -
Alfred NESWADBA
