05-03-2019
06:29 AM
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
05-03-2019
06:29 AM
The bat files operate in the command window which is like DOS. The structure of the bat file is very similar to old DOS .bat syntax (if not exactly the same, but i dont know enough to say that definitively).
AutoCAD coreconsole is a program that runs in the command window (unless suppressed). The actual AutoCAD operations are not DOS as the are executed by coreconsole. Coreconsol is AutoCAD without a GUI. You can just open up a windows command window and run AutoCAD coreconsole solely from the command window so it will look everything like running it all from DOS.
CADnoob
