05-02-2019
12:48 PM
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
05-02-2019
12:48 PM
Save it as a drawing with a reasonable insertion base point [either use the BASE command in your example drawing to designate what point in it will be used as its insertion point when you INSERT it in another drawing, or MOVE all the pieces to put a reasonable corner at the drawing origin], and just INSERT it when you want to use it. Then EXPLODE it if you need to mess with surrounding wall thicknesses and/or intersections that may vary, use a different Dimension Style, etc., in different usages. A routine could easily be written to Insert it and Explode it for you.
Kent Cooper, AIA
