395 Vistas, 2 Respuestas
how to automate a floor plan
I'm trying to automate an ADA bathroom floor plan and not sure how to do it. any help
Kent1Cooper
en respuesta a: Anonymous
Save it as a drawing with a reasonable insertion base point [either use the BASE command in your example drawing to designate what point in it will be used as its insertion point when you INSERT it in another drawing, or MOVE all the pieces to put a reasonable corner at the drawing origin], and just INSERT it when you want to use it.  Then EXPLODE it if you need to mess with surrounding wall thicknesses and/or intersections that may vary, use a different Dimension Style, etc., in different usages.  A routine could easily be written to Insert it and Explode it for you.
Kent Cooper, AIA
s.borello
What do you mean by automate?  Please elaborate.
